As long as someone lives in a colder climate this should be OK, although just running a cardboard grill block and underbody corrugated plastic (coroplast) should be fine in that situation. If someone is doing a lot of stop/go driving in higher temps they may need a normal size radiator with a fan to make wind and remove heat.
