Old 11-27-2010, 12:33 PM   #33 (permalink)
99kleansi
99CleanEM1
Originally Posted by Joseph Davis View Post
No, a wideband isn't needed for daily operation. Only for the initial tune on the vehicle. Narrowband O2's are actually very accurate away from stoich; but their curve is logarithmic, a low amplitude analog signal prone to being molested by ground ofsets, and their calibration varies with sensor temperature. Run a heated four wire sensor a little ways down the exhaust stream so engine heat doesn't molest it - approx where the driver's feet are on a distributor Honda is fine - and make sure you keep the sensor's power and signal grounds seperate until they finally reach the block which is THE ground point in a car's electrical system. Chassis grounds are garbage.
I've been doing a mini engine R&D project with a friend, putting the 01-05 D17 cranks into earlier D16 engines. There's a lot of misinformation about the reliability of this combo resulting in few people doing this combo - it's mostly kids who don't know how to build an engine messing things up.
Anyway, 9:1 static CR 1.7 stroked D16Z6 1991 RT4WD wagon with an Evo8 turbo and Siemens Deka 500cc (at 43.5 psi, aka 04-05 SRT-4 injectors). Part throttle maps were tuned for 15.5-16:1 AFRs, and runs a (fresh!) stock O2 sensor whose lean/rich switch point has been set to 0.39 volts. The combo makes 185 whp at 7.5 psi and 235 whp at 12.5 psi, uncorrected figures. In 4WD, some spirited driving, 32 mpg. In 2WD, normal driving, 43-44mpg. Wagons are heavy and aerodynamic bricks, 4WD/AWD drivetrain loss is appreciable, and the air is thin as well as the land not flat up here on the mountain.
A third of the gains are tuning the vehicle. A third of the gains are having a working O2 sensor with a lowered switch point. A third of the gains are having a modern pencil core injector that atomizes far far better than earlier injectors. I've also spent a number of hours on the dyno placing the ignition event at the optimum point for all NA loads and speeds under 4000 rpms, as lean burn doesn't accomplish as much if the ignition timing doesn't place peak combustion pressure accurately at the "sweet spot" where the rod has best mechanical leverage against the crank.
This is about the most sense I have head on this site. What injectors are you using? Injector dynamics are very good and are all balanced within 5% of each other in any given set.
Are you tuning each individual cylinder according to EGTs or for overall advantage. The ID injectors will make this real simple as the RC injector in the past were not as linear. The IDs also work real well at high pressure around 100PSI to def atomize the fuel.
I am under the impression that no motor actually runs @ 14.7:1 as that would be unrealistic. I would assume you could get around 15:1 or 16:1 with almost no load on the engine. Throttle tip in would reduce the ignition in milli seconds and allow the injectors to richen the mixture to allow for acceleration with more timing.
In some programs on the Hondas you can allow the dwell angle in the distributor to accumulate more spark energy in the coil to help a more efficient burn with out having to fork out for an ignition system that would allow more sparks over a certain amount of degrees of rotation.
