Make sure you get proper heat resistant alu foil.
The thin stuff used for insulation blankets won't work underneath the bonnet.
The thin plastic carrier (PET in some cases) also needs to be able to withstand the temps under the hood.
While none of the ZX-insul products actually seem to be made for high-temperature applications, such stuff surely exists.
