Old 11-27-2010, 01:53 PM   #108 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Rokeby, which one did you use then ?
A PE-carrier has a melting point around 120°C/250F depending on density, that's too low to safely use it in an engine bay.
A PET-carrier would have a substantially higher melting point, around 250C/480F, which would make it useful as long as you avoid direct contact.
