Old 11-27-2010, 06:23 PM   #15 (permalink)
Arragonis
The PRC.
Another vote for the engine swap. What you may find is that the gearbox / clutch design is shared with a smaller engined model or even a smaller Mazda (323 1.6?) so an engine swap may be easier than you think especially if you get the engine from a scrappy and do the spannering yourself. You also get the advantage that your 2.2 gearing may be high for a 1.6.
The Supercharged Diesel engine is better than your Petrol for FE but not a good design - nobody followed Mazda into that dead-end for a reason.
Alternatively go for a smaller (and smaller engined, lighter) car. Unless you need the size its not worth it.
