I would trust the GPS. IF you can find the specs on your unit, it's probably accurate to within something like 15 meters total point to point. If you didn't hit any resets or move without the unit on, it should be the best way to measure distance covered. I found my Jetta odometer reads 10% high, which was a little disappointing, but its good to know the truth
