Old 11-28-2010, 12:10 PM   #10 (permalink)
jamesqf
Originally Posted by TomEV View Post
The volt has a 'mountain mode' setting that will force the ICE to charge the battery pack. If the Volt encounters a steep hill with a depleted battery, it will only be able to go up the hill as fast as the smallish ICE can propel the rather heavy Volt.
This makes sense, and would make more sense if you could turn it on manually before getting to the hill.
Though I've never understood why most people seem to think of the plug-in hybrid as having/wanting to run on battery only until that's depleted, then running on IC engine alone. Seems to me that on anything more than a short trip, you would get better results using both together.
