A manual safety switch is made. This cuts the power off. The only problem is that it requires running the traction voltage into the passenger compartment. I chose to have the pull-handle in the passenger compartment, just like the old-fashioned choke cable. This cable should be a nylon rope because it does not conduct. You could put a plastic carrying handle on the end, just like in dept. store heavy packages.
