Thread: Grill Block
Old 11-28-2010, 03:42 PM   #11 (permalink)
Thymeclock
Originally Posted by BHarvey View Post
Made my first template for the block, now I need a clear material that is bendable but pretty rigid and a good way to install the blocks, IE aesthetics in mind.
I used aluminum trim coil to make the grille blocks for my '09 Aveo. It's extremely light, easy to cut and easy to bend; it can be fastened using screws and tinnerman nuts.
The lower grill block is behind the lower grille and is invisible, permanently mounted, painted black. The upper grille block is also painted black and is attached externally by two long screws through the grille. It is only attached in winter as it would be too restrictive for summer temps.
Grille blocks will help the car warm up a bit faster. However, aerodynamically it had no effect on the car's FE, nor did the front belly pan I made.
