Old 11-28-2010, 11:00 PM   #13 (permalink)
todayican
Building the future! :-)
well... a bit of a setback, after all the measuring and drawing and redrawing and cutting etc, the clearance for the rear riders legs dont work as they reach around the forward riders butt, need to start over :-(
But...
Ive been toying with the idea of going side by side and using 2 "mini canopies" for each rider (If driving solo, I could remove the passenger canopy and stow it)
I dug this up its called a Sea Lion, Im thinking exactly like this except with:
Riders moved forward 10 to 12"
dual windscreen / enclosures instead of the single windshield
cleaner tail area but with that same taper.
What is the consensus of the look of the car (Yep, im talking to you Frank) :-)
Threw in a 20 Cup to give an idea about the seperate windscreens and "divider" Also
ID:	7445   Click image for larger version
ID:	7446   Click image for larger version
ID:	7447   Click image for larger version
ID:	7448   Click image for larger version
