Old 11-29-2010, 12:26 AM   #22 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
It's fair AFAIK, both are running in charge sustaining mode. The Fusion gets worse highway mileage because it's a fullsize car, not a compact, but it should also get worse city mileage. The problem with the Volt is that running everything through to a generator, then converting that back to mechanical power via the motor reduces efficiency by ~15%-20%, and the single speed trans for he electric motor hurts a bit too (~5+%). If they sent mechanical power directly from the engine to the wheels in charge sustaining mode they would do a lot better than the Fusion hybrid and be very close to a Prius.
