do not use ether you will cook your glow plugs/wash oil from the cylinder walls or otherwise give it a low compression ether addiction.
Install a block heater of some sort. A propane torch applied to the head (not to the valve cover) can bring up the temperature enough to get it to fire up. Warm to the touch but not so hot you burn things keep it moving and dont heat the injector pump, glow plugs, wires, hoses or other bits.
Double cycle the key so the glow plugs get a little warmer has helped the oil burner get over the hump on a cold morning.
How long have you cranked? How cold is it out? Have you checked to be sure your plugs are heating?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
