Old 11-29-2010, 12:10 PM   #25 (permalink)
brucey
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
You simply unplug the white connector under the dash.
Pictures here: DIY: Disabling DRL (2000-2004) - Subaru Outback - Subaru Outback Forums
I used to also pull the ebrake up to disable them, but once I adjusted my ebrake properly I didn't want to grind into the brake to turn them off. Plus the brake light coming on was annoying.
Also. 60$ for .5 MPG isn't too bad. It's a shame it's only at night, or I'd jump right on it. Although, with just 70 watts saved it'd probably be more like .25 mpg. Which is a bit harder to swallow. I actually have interior and license plate LED's but only because they burned out on me and I didn't feel like changing them ever again.
