Old 11-29-2010, 12:44 PM   #15 (permalink)
JasonG
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
If the glow plugs check out fine, get a block heater, they are a wonder!
I also thik youre getting some fuel gelling if it wont go above idle for a while. VW sends fuel back to the filter to try and heat it up some. That can help but takes a few min.
To check, pull your fuel filter when its cold. If it looks like it has Vaseline on it, your diesel is gelling.
I am a fan of "Pri-D" but "seafoam" works well too.
WD-40 is safe to run a diesel on. Unlike ether it will not harm the engine. Mechanics on the big diesels use it to keep the engine running while a new injector pump primes itself. I keep a can in the truck for the just in cases, Haven't needed it yet though.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
