more vac = less throttle position..
but the thing is to stay at a consistant 55mph on a flat stretch on a windless day requires about 14 vacuum where as on the same stretch the truck is willed to right around 60 and the vacuum is at 17..
the higher the number, the less throttle position your using..
anything 20 or higher is decelleration..
