Old 12-01-2010, 12:54 AM   #8 (permalink)
Sulfuric
Lil Sulf - '94 Toyota Corolla
90 day: 47.62 mpg (US)
You might consider Lexan. I used the stuff when I needed a clear canopy for an electric car I built in high school.
Here is the bubble bursting moment though. Your car will not be legal because lights must be mounted to the furthest points on your car, meaning all the way back, and all the way at both sides.
You would especially want these lights if you have a long clear back-end you don't want rear-ended.
I believe you, however, laws are different for each state so maybe I can get away with it . . . I would probably add a light of some sort if I went through with it, it's just that I'm really bad with wiring.
I could make it just a kammback from the roof to the trunk and that would still help a lot. Then I wouldn't have to move anything.
And that's without a Scangauge o.O
