Old 12-03-2010, 03:50 AM   #4073 (permalink)
DJBecker
The Cougar board uses a NTC thermistor. It's inexpensive and easy to design around, but it's not linear. Combined with the loose tolerance of the surrounding resistors, you won't be able to do a direct conversion. Instead you'll need to create a curve fit polynomial to match your specific parts (as above) or a calibration table that you interpolate from.
Here are the notes I took when selecting the temperature sensors for our controller. We had a slightly different set of design goals.
- Most of the sensors were for reporting, rather than thermal limits, thus a calibrated result was important
- We wanted more sensors, and individual calibration would be a bit of a PITA
- We wanted automotive CAN bus reporting, thus needed degrees Celsius reporting.
Temperature sensors
The LM335 is inexpensive and has an output voltage in "degrees Kelvin",
2.73V at 0C, 2.98V at 25C. We need a 2K ohm bias resistor for 5V operation
to get the approximately 1mA of operating current
A LM35 is a bit more expensive, but requires no bias resistor, uses
less current, and has a source lower impedance for a better A/D conversion.
(The A/D converter has trivial leakage current, but the sample
capacitor requires a low impedance source to charge correctly during the
short sample period.) The down-side is that it outputs 0V at 0C, and less
at lower temperatures.
The least expensive option is a themisor, where the output is non-linear
and depends on the bias reistor. The Cougar uses a B57862S103F40 thermistor
with a two resistor bias tree, and a 0.1uF cap.
An alternative is using digital sensors e.g. one wire. They aren't much
more expensive, and save on A/D channels, but may take a little more
processing time.
TI TMP75AIDGKT Digital temp sensor 2 wire 8 MSOP Digikey $1.54
Dallas DS18B20 One-wire, possible single pair operation, 750msec
$2 in medium quantity, $6 in a probe format
And the comments from the CAN reporting code
case 0x05: /* Coolant temp A-40 -40C..+215C, use heatsink temp. */
/* Assume a LM335 where Kelvin = 100 * 5V * (count / 1024)
* Our baseline temp is -40C or 233.15 Kelvin, or 2.33V
* which is an A/D reading of about 477
* DataA = ((500 * rt_data.raw_hs_temp)/ 1024) - 233 */
can_cmd.dataA = (125 * (rt_data.raw_hs_temp - 477)) >> 8;
good = 3;
break;
The Following User Says Thank You to DJBecker For This Useful Post:
mpgmike (01-19-2022)
