Thread: Eaarth
Old 12-03-2010, 08:27 AM   #128 (permalink)
NeilBlanchard
Last week saw the coldest 28thNovember Britain has ever experienced, and Wednesday was the coldest 1st December. By contrast we have not broken a heat record for a particular date since 10 May 2008.
Guess what? If too much ice melts in Greenland, and the fresh water lowers the salinity of the surrounding ocean -- the Gulf Stream current could stop! It is already much slower and weaker than usual -- and guess what the Gulf Stream current does?
It keeps the UK much warmer than it should otherwise be! Look at Google Earth and line up the latitude lines of the UK with other countries...
Guess what happens when the Gulf Stream stops flowing (among many nasty results)?
The UK will go into an ice age. So, you are seeing the very real results of Global Climate Change.
