Originally Posted by BHarvey
My last two tanks were 32 and 34 respectively. This is combined mpg for town/hwy in Atlanta. My 34 was with 44psi and the 32 was with 38psi. The temp had dropped 20+ degrees and tire pressure dropped with it to the tune of 4 psi. So this brings me to a question about tire pressures.
When you adjust pressures to lets say 44psi on a 35F morning and later it heats up to 70F, but without having driven the car, will the pressures now be well over max?
I am aware that a higher inflation pressure reduces the amount of heat the tire generates, and this in turn makes the pressure rise less from 'undriven pressure' to 'driven pressure'.
Yes, the pressure will go up when the ambient air temp increases to 70F. Its basic universal gas law PV = nRT. Or P=nRT/V. If the temp goes up, your pressure will go up.
