Old 04-20-2008, 03:03 PM   #4 (permalink)
Silveredwings
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
Originally Posted by Sethro View Post
Image says it all:
Not sure it this is doable with ratio's, transaxle, etc. But what a way to go. I mean you could easily use regeneration in this system.
I'm not sure the image does say it all. If this is architecture is derived from something AWD like a subaru, the engine supplies power to the front and rear differentials through a third open differential (drawing on left). For example, if you just took the central driveshaft off, you end up with a freewheeling flange (for the rear diff) and the front wheels wouldn't get any power.
If you put an electric motor on the open flange (drawing on right), you'd be pushing power from the motor through the centr diff. you'd have to have the ICE and electric motor delivering torque at the same time in order for the car to move. If the motor was delivering more torque than the ICE, I think it might actually turn the ICE backwards.
If you welded the center diff, it might work as you envision.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
