Old 12-03-2010, 01:11 PM   #3 (permalink)
wriley4409
Yes, you should remove the electrical connector from the compressor if you plan on doing this modification, although it won't make much difference. Simply disconnect that wiring plug and secure the wire with a zip tie.
Most vehicles do engage the compressor on the defrost setting, but you don't necessarily have to do so. Simply blowing fresh air onto the windshield is somewhat effective, and adding heat to the air makes it even more effective.
