Sorry to double post...
Start the under tray from the rear 'cause wind will be coming from the front, this way it overlaps rearwards/air flow.
Great on the cross braces for the rear tray.
Don't cut it the panel, air will flow to lower pressure and then "raise" the low area to smoothen out turbulence, lot smoother and cleaner.
