Old 12-06-2010, 03:20 PM   #227 (permalink)
GeneralAnarchy
It was a manual reel, the cheap kind with a handcrank, not the fancy spring loaded one. I got one just to scavenge a high-temperature cord. The reel itself can be discarded, or preferably, restored with a cheaper cord. The standalone extension cords at home depot and lowes are not very good so I did not use one for the engine compartment. The cord is tied behind the grille so, like the block heater, it only pulls out a little bit so an extension cord can be plugged in.
I drilled through with 3/4" bit and one of those Harbor Freight right-angle drill chucks, and then I fit a rubber grommet. It is slow and time-consuming, and it's probably worth it well in advance to make a wish list of add-on electronic accessories you want to feed through. On my setup, most of the 25 feet or so of extension cord runs along with the Enginer cord.
The Following User Says Thank You to GeneralAnarchy For This Useful Post:
kaval (12-06-2010)
