Old 04-21-2008, 04:52 AM   #11 (permalink)
Nden
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
mims, u'd need the motor, egr -black box mounted to firewall, IM, ecu, and 5-wire 0xygen sensor -$90ish if u look on net. U can use same motor mounts but if its that old i'd recommend some Innovative polyurethane ones the red 60A softest rated $269 ebay. Due to wear your stock ones are shot and you prolly need to replace the 2 torque mounts too(under and to the front). The Vx wire harness ofcourse unless somebody here knows how to modify yours. In fact, I don't think anybody makes polyurethane torque mounts so i may just try using silicone caulk to fill in some new oem ones. Plus the Innovative ones are billet and look nice.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
