ok no problem. I had that happen in a forum once. My system said I was posting but nothing was actually appearing on the site for some strange reason. Very odd. just wanted to be sure :-) hehe
you might need a custom hose built but its easy stuff really. then you have the flow rate of both regs which should more than surpass what you need.
on my RV I have one of these since it has two tanks but its a "switch" you spin it one way or the other to use one tank or the other. so should be easy to get a simply "y"
