Old 12-08-2010, 08:17 AM   #1 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Tapping into signal wires
What is the best (ie safest) way to tap into a signal wire? There are a few sensors that I'd like to monitor, the "signal" is usually just the voltage (eg 0V=open, 5V=closed, etc). Since taking the plug or socket apart is too hard (if at all possible), I have to somehow get into the wires. I can see three options:
  1. Cut the wire, then solder it back together with a third wire for monitoring,
  2. Same as above, but without cutting, only stripping some of the insulation off,
  3. Insert a metal sewing needle through the insulation and solder the monitor wire to the needle.
Since I want to monitor the signal only for a short period of time, I would like to be as non-invasive as possible. Options #1 and #2 may lead to problems with corrosion in the future, so is #3 the best?
