Originally Posted by Piwoslaw
I think it won't make much of a difference. If your block heater isn't enough, you can glue a heating pad to the oil pan and/or transmission (or even to the block, like MetroMPG did).
You could be right, and after looking under the hood, I'm not quite sure where I'd put it anyway. But, I know that a friend of mine from years past found a heat lamp mounted under his VW Beetle helped quite a bit with cold starting. I thought the heater might do the same thing, if it could raise the under hood temp. enough. Oil pan heaters do help, but they have to be on a smooth surface below the oil level. I could put one on the engine pan, but there is no flat spot on the transmission. Also, I think the ECU looks at coolant temp., not oil temp. when determining fuel mixture.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
