Old 12-09-2010, 02:58 AM   #7 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by RobertSmalls View Post
If you can get at the ends of your wire harnesses (e.g. where they enter the ECU), you can get a narrow probe in there without piercing the insulation.
That's the problem - where I could, I took the plug/socket apart and added a thin wire to the pin. But in many cases the harness is waterproofed and can't be taken apart without breaking something. I've tried, but too many layers of plastic and silicone.
Originally Posted by Thymeclock View Post
You will need a few, very sharp dental instruments
Dental instruments (chill runs down spine)...
(I've only been using this technique for 40 years. If you find it useful a 'thank you' would be appreciated.)
Thanks to everyone
