Originally Posted by ZOMGVTEK
I would probably start off blocking the whole thing, assuming we are talking about the lower section and there is still a upper one for cooling.
I do not understand what you mean with the upper and lower sections. I think the IC is linear. As in air goes in one side and comes out the other. Like a pipe. As apposed to my Probe's IC that had the inlet and outlet on the same side.
Thanks for the suggestions. Now I need to put them to work.
What is the best way to attach the block? I was thinking of using chloroplast based on several posters here speaking of it's wonders. And zip ties. I do not want something more permanent, because I have a warranty on this car.
