Those who have major doubts about global climate change -- you can figure out if you want to be on the same side as this guy:
You decide: do you want to be on the same side of this critically important issue as Don Blankenship, or not?
Nice try, Neil, but it's pathetically obvious. The technique is called 'guilt by association'. Put up a photo of any villain and use the propaganda trick of saying "if you do not support US (or doubt our activist position), then you are on the same side as HIM.
And the sheeple, the new citizens of EAarth said: "BAA, BAA, BAA!"
