BIG UPDATE!! I found a VX in a junkyard today with the EGR box intact. I looked inside and found that the exact same two devices are in the 94-95 Accords. Inside there is a EGR vacuum control valve and an EGR control solenoid valve. Basically just a two prong electrical plug and two vacuum lines; one to manifold vacuum and the other to the EGR valve itself.
