Thread: Insight 4x4
Old 12-11-2010, 01:51 PM   #24 (permalink)
Staska
Originally Posted by Hugh-Falls View Post
Staska: Yes, the ideal location for the drive pulley centerline would be the centerline of the rear beam pivot. When I initially considered this approach, finding both the available necessary space and suitable available components to make this method work had evaded me and continue to be the insurmountable obstacles both with regards to money and time to get it done. Cutting into the side of the Insight and coming up with something that works and looks correct/good is not easy or cheap.
Sorry when. I dont see whole image. From my point of wiev, i cant see how you will round chain across suspension beam.
Btw - how does drive axle in prius look ? Does it have so colled intermediate shaft ? or it is only one part for one side..
