Old 12-11-2010, 04:03 PM   #979 (permalink)
TheSilverBullet
Silver Bullet - '00 Pontiac Firefly 4 door model
90 day: 12.74 mpg (US)
Originally Posted by ben98gs View Post
If it is truly your speedometer that is broken, then it should be pretty accurate after you calibrate it (which might be kind of hard unless you have a GPS to use and an odometer). But if it is actually the VSS (vehicle speed sensor) that is causing your speedometer/odometer to not function correctly then the MPGuino will not be much help because it gets it's signal from that same VSS.
I am within 0.2 miles on an over 400 mile tank with what my odometer reads compared to the MPGuino. So I am WELL within a less than 0.1% error on my odometer reading.
It's just the cable-driven speedo, so the VSS should have no effect on the speedo and in fact seems like a good idea to me. Does anyone have an opinion on this unit here ?
GPS Head Up Display, GPS Receiver, Speed, Bluetooth on eBay.ca (item 140463312111 end time 06-Jan-11 02:57:32 EST)
2000 Firefly 4 dr Automatic
