Old 12-11-2010, 04:43 PM   #24 (permalink)
TomO
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Originally Posted by Ryland View Post
Tomo, Any idea how accurate that cold engine 25mpg figure is? I can't remember if you have an MPGuino or not.
And what type of engine heater do you have? oil heater, coolant heater, stick on block heater?
That Cold Engine 25mpg is just a number I pulled since the car is supposed to get nearly 40mpg city (fully warmed). I figured it'd get more than half of the City mpg as it warmed.
I have an MPGuino.....it's still sitting in two major pieces since it failed to work properly when assembled. There were some solder bridges that I didn't check for on the pre-soldered IC. They have since been cleaned up but I haven't stopped by Radio Shack to get some more pins to re-connect the LCD to the main board.
I used the OEM style block heater which is a screw in type wher ethe engine block coolant drain is located. Pics of the installation: HERE
