Old 12-11-2010, 07:03 PM   #8 (permalink)
dvldrmmr
Zeke - '81 Mercury Zephyr
The Beast - '84 Ford F150 4WD
you could get another connector, and solder pins on the end to fit into the original connector, splicing off a wire as in #1. then when you're done, just unplug your "piggyback" setup, and plug the original connector back in. sort of a man-in-the-middle type setup, and no worries about corrosion/broken wires with method #3. just a thought.
