I did the test today. It was around 0°C (32°F) this morning when I started, light drizzle. I idled for 30 seconds every 15 minutes, recording the coolant temperature on the ScanGauge when starting and when stopping the engine. I noticed that right after starting the engine the 'old' (when the engine was previously stopped) temperature showed for 5-10s before it was updated. I also recorded the total energy used by the heater.
During the test the grilles were blocked, but I removed my
thermal insulation. I replaced it after 2:30h, so the last 30 minutes of the test were with the insulation.
time | coolant
temperature
- start (°C) | coolant
temperature
- 30s later (°C) | total energy
used (kWh) |
0:00 | 1 | 1 | 0.00 |
0:15 | 1 | 9 | 0.15 |
0:30 | 10 | 17 | 0.27 |
0:45 | 18 | 23 | 0.40 |
1:00 | 23 | 27 | 0.54 |
1:15 | 25 | 31 | 0.67 |
1:30 | 28 | 33 | 0.81 |
1:45 | 31 | 35 | 0.93 |
2:00 | 33 | 37 | 1.07 |
2:15 | 35 | 39 | 1.20 |
2:30 | 36 | 40 | 1.33 |
2:45 | 38 | 42 | 1.49 |
3:00 | 39 | 42 | 1.60 |
What matters is
where you're going, not
how fast.
