Old 12-12-2010, 06:24 PM   #34 (permalink)
saand
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
msc,
You are likely to have an issue with your clock idea, you will have a big problem getting accurate timing unless you sink the clock to some external (more accurate) timing device than what the processor runs on.
There is a standard issue in timing applications for electronics where time will drift due to accumulating errors. So unless you are planning on making use of a clock crystal (oscillator that runs at close to 32 k Hz) then you are likely to have issues with your timer.
Feel free to prove me wrong but thought i might save you a bit of time because i have had this problem myself.
