Awesome! :-) I found the water drain pan searching for steel dish sled, the steel dish part hooked up to a aluminum drain pan, and utlimately they are more commonly made of rubber/plastic now!
I'm kinda thinking of might be able to use a 28" heater drain paint to do some aero on the front tires. no a full block, but use the side part as a mounting point, and use the flat to fill in the gap around the tire. Leaving it straight black plastic will give it a bit of stealth. :-)
I just thought of the sleds today case I saw them in an ad, an went no ****, instant wheel skirts! hahaha Figured I would pass the sleds along!
