The fuel you save is going to be burned and more when you call a tow truck.
And no goo will help a total blowout. I've had two recently, one from a deep pothole at 45, almost went into a canal, and the other backing into a parking space, I hit the curb which had a old busted iron plate that went into the side like a knife. Both times I was back in business quicker than a tow truck would have arrived.
Weight is mostly a factor in acceleration, and more is better for long glides, but worse in pulses. If you drive over 40, weight (rolling resistance) is pretty negligible.
My bike runs on dihydrogen monoxide.
I like to use these acronyms
