Headliner construction
I am finally building a headliner for the Jeep's hardtop.
I am using cardboard with headliner material on the inside & a layer of aluminum foil for a radiant barrier on the outside. The question I have is which direction should the shiny side be facing, toward the cab or the sky? It is more to keep heat in than out.
Thanks
Don
