Old 12-13-2010, 01:46 PM   #170 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by robchalmers View Post
Quick update,
Going to look into a complete top grille block and maybe a better aftermarket airfilter. these paper element one barely seem to last 5k before they're choked with Road grime.
Yes the paper element filters can plug up quickly but it shows they are doing their job. If you do the research you'll find these oiled gauze aftermarket filters don't filter as well. Neither will the foam rubber ones.
Personally I would rather change my filter every 5K than have fine grit get through and wear down my rinds and cylinder walls. Compression is essential for diesel efficiency.
Consider relocating your intake.
