Originally Posted by redpoint5
How much over the sidewall rating do you run in PSI? As a general rule, what % over sidewall do you consider to be safe?
I run 45 psi, near but below the sidewall limit (51psi).
I tend to wear out the edges of my tires first since I don't brake before entering turns, so perhaps over-inflating by a decent amount would help to even the wear out.
Same here, and the higher inflation seems to help to spread the wear more evenly.
