Originally Posted by slowmover
Just buy the best tires, observe the placarded numbers and get a tire gauge that can be calibrated. And use it.
I'm with you on the good tyres and pressure gauge, but the numbers for tyre pressure on the car manufacturer's placards are often way too low !
I originally started to increase the tyre pressure (set at placard numbers) to cure a handling and wear deficiency when I put on 17" wheels.
At the placard values, the car was wobbling on its tyres, while the outside threads were almost melting away like butter in the sun.
But I won't go over the tyre manufacturer's max pressure rating.
Surely they keep a healthy safety margin, and I'd like to use that
