Originally Posted by RH77
I'm still a noob to Linux-based systems. I'll give those a try and see what happens. Thanks!
IIRC it was a
Jackass minimal CD. Same install for a stage three as Gentoo, although it'll probably take a day or more to compile everything depending on what you need. Also, if this has windows on it already, you can try UNetBootin to install from within windows.
