Old 12-15-2010, 09:47 AM   #307 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by lunarhighway View Post
have you considdered experimenting with a dorsal fin?
Why would Jim consider adding area to the rear, while the centre of pressure is obviously still forward enough not to cause handling issues in sidewind conditions ?
A fin wouldn't cure an aft shift in CoP, it'd make it worse.
If not perfectly symmetrical to eliminate "lift", a vertical tail surface would add a permanent resultant sideways force working on the vehicle.
A fin also adds to the frontal area, and thus to the aerodynamic drag, the reduction of which is why the tail extension was built in the first place.
