Do you mean turn off the LCD when the ignition is off? I assume you mean that you would want a pin to turn off the LCD when you want to release the keys from the igninition. Otherwise you want the LCD to stay on when you cut the engine during P&G'ing. Is this correct?
Otherwise why not use a power source from the car that cuts off when the keys are in the OFF position.
