Thread: Hydrogen Engine
Old 12-16-2010, 07:46 AM   #76 (permalink)
tf4624
Eco of course
[QUOTE=IamIan;209787]thank you for the compliment
But flattery will get you no where.
Smart ass won't get you anywhere either. do I detect an EGO in the way here?
No need to retype each quote.
Don't need to, if you can't figure out what my answer are.. then go back to school.
Option #1: copy and paste
Option #2: read more carefully when you click on the quote button. it inserts into the entry screen the commands for the quote feature. the command that starts it at the beginning of a string of text. and a command that ends the quote feature for that string of text. you can use those beginning and end commands to break up the quote. Which as you can see from reading the forum... is the way everyone does it.
well isn't that just awesome? "everyone" well there's a first for everything
I figured out what you did with the bold ... self evident by my pulling your quotes out of mine... not complicated.
Wow, you got a brain, see if you had used it we wouldnt have this crap about quotes and me bolding, you would have obviously understood I did that, not to missquote you but to answer what I wanted, and doing it my way.
I think you have mis-understood what is means to quote someone... the quotation marks example ... "I say this" ... or by using the forum quote feature ... anything inside the quote , is the word for word what the person referenced said, or wrote... by the very definition of a quote ... what you did is falsely putting words in someone elses mouth... in that case mine.
You must really want it done a certain way, but i choose to still answer your questions reguardless to some way you want me to answer quotes. Well I will answer the way i fine fit for me, and not you.. as you dont own me and nor do i tell you how to live and do what you want.. I might suggest something but not tell you to be who you are.
If you have missed it ... everyone else that quotes you does not insert their comments into the quote itself ... the comments are always separated from the body of the quote.
Thanks for your concern, as I didn't forget or miss it.. Thanks
Adding bold to the text inside a quote the the accepted method of drawling attention to a specific part of the quote... which you still used incorrectly.
No explaination needed, as your not the controling party of others, so get off whatever your smoking and control your life not mine or anybody elses.
I'm not going for the "CORRECT" Way of doing things.. thats the great thing about life, you can do what you want if you chose to.
Credit is given when credit is dew.. and i guess you want your star on the walk of fame.. well congrates captain .... take whatever credit you want, I could care less and no I won't take credit for whatever crap bable you decide to write from here on or from before, cause its not worth my time with you. I know you and me have better things to do then argue about stupid quoting systems and other grammer issues. now if you want to carry on with the topic.. I'd be glad to forget all this b_LL __H_T and get on with the show here
