Old 12-16-2010, 01:15 PM   #3 (permalink)
rbrowning
Just for my own education, have you measured what your car consumes at a cold idle without mods?
I am curious because from what I see on my car it really cuts total fuel consumption to let the car run a few minutes to warm up without a load. I know that the fuel burnt at idle is total waste, but I believe, from what my display shows me, that it is more than offset by the increase in efficiency when under load.
I don't have a aftermarket OBD2 display, just the factory display that only shows the instantaneous MPG to be zero. I would like to know what engine you have and what the consumption rate per hour is while you are idling cold.
