Old 12-16-2010, 05:42 PM   #11 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by aearles View Post
Also, what are you guys using as fasteners? I would like to only run it during the winter but have it easily removable and replaceable instead of using zip ties etc, and of course I want it to look clean.
You can put the grill blocks on the inside.
Stealth
Slightly less efficient than a smooth front, but it'll still work OK.
It's how car manufacturers do it.
I'd block the entire upper grille, and half the lower grille.
If air can get to the radiator behind/below the front spoiler, block the entire lower grille.
Keep an eye on the coolant temperature though !
