Originally Posted by MPaulHolmes
Well, ya, but I was thinking of doing another one that still uses the atmega. The only reason I was using the dspic was because I wanted it to have CAN, so it can talk with the bms and charger while driving. I really want to get a plug-in hybrid working.
PAUL
Well, I do not want to jump in to conclussions but,
Surface
Mounted
Components will be a little hard to many DIY builders to work with and will be a real task to place a SMD dsPIC on the board in the right way.
Having in consideration how often the microprocessor get blown by any circumstances, the replacing will be difficult if this are NOT socketed.
Or, Are you planning to provide the control PCBs with the passive components already installed?
